I run the bsb stlye birdcages and i have sometimes heard that when the car is at ride height that you want the angle of the birdcages to be at 0. I was just wondering if this is true or what we be a better way to put it? I was also wondering, ive heard that you dont want the left rear top rod to exceed 45 degrees, and i was wondering if that is true too? Thank you for any help.
Setup question!
We index the lr with spring behind into the spring about 2 degrees at ride ht.
You could move the lrt bar down on the b/c and index it that way for quicker bite, just make sure your shock doesn't bind on front of b/c.
I've heard the same thing about the 45degrees at full drop, ours is only 38. Good luck.
