Have an 03 Warrior mod. Need any info I can get as far as ride heights, rear end location etc. Any help appreciated. Have the setup sheet from their website but much information missing or confusing. Also called them and got very little help.
Need Warrior Mod Setup help
Warrior has a good website with lots of info.Metric clip more then likely, Or call them Im sure they will put you in the ballpark. Springs could be your biggest help. Lots of different front clips out there,they all require different spring setups.BUSTING OURS TO KICK YOURS
Thanks, but I've tried both. If you look at the setup sheets on the website lots of critical info is missing. Also called them twice. Very little help given. They said that the person who knew about their modifieds was no longer there and sorry !
warrior mod setup
I run a 03/04 warrior OWM. I set my ride heights the way that Kevin Shaw explained how to do it in a post he did about a year ago, If you search K.shaw you will find it. My wheel base is 111" but before I switched to nova lowers it was 110".
Call for info on warrior set up, may have some #'s for you 615-202-7343Originally posted by modracer03 View PostHave an 03 Warrior mod. Need any info I can get as far as ride heights, rear end location etc. Any help appreciated. Have the setup sheet from their website but much information missing or confusing. Also called them and got very little help.
