Anyone have any suggestions how to keep the left front down? Shaw chassis 600 across the front, 200 rr and have tried a 175, 200, and a 225 on left rear. Have had numerous bar angles but nothin keeps the LF down. Runs up front with a feature win but dont have any idea how to get it down. I think it would be alot easier to drive if it stayed down. Any ideas would be appreciated. Thanks.
Lf down
How much lr drop do you have? Angle in jbar too much or too much pull bar angle, some of the things to look at but look at the lr drop 1st and good luck.
Lf down
We run a Shaw. My first thought would be left rear drop. Kevin says 15.25 to 15.75. Also check upper left bar angle at full drop. Over 44 degrees will definately get LF off ground. We stay around 42 when slick and 38 when tacky. Jbar split is another, we run between 3 and 4 inches.
John
