Loose in and on throttle until car gets straight
  • Flyin Iowan
    • 558
    LF 550 RF 600
    LR 200 RR 175
    QC jbar top on pinion with 5" rake
    1/4 lead in LR
    18lbs bite
    52.3 left
    57.5 tail
    1 1/4 stagger
    LUB 24 deg
    LLB 4 deg
    RUB 18 deg
    RLB 0 deg
    car doesnt feel like it transfers to RR unless there is some tacky patches in track for it to get ahold of
    car also feels like it drops on LR and doesnt roll on RF if im in traffic and have to back off early. Would jacking up LR and lowering RF help this?
    Would dropping jbar 2" on both sides, going to 550 RF and 200 RR be to much of a swing?
    Chris Zogg
  • Flyin Iowan
    • 558
    Also, running on American Racers and this is a slick little 1/4 mile track. medium banked.
    Chris Zogg
    • Darkstar15
      • 90
      Loose
      Try the Jbar first, maybe not so much split 3-4 inches. If not enough, move the LR back that 1/4 inch and try it. If still not enough, move RR forward. Reducing stagger would also help, but you do not have alots now.
      John
      • Dirtrunner35
        • May 2010
        • 632
        Air pressure ???
        • Flyin Iowan
          • 558
          LF 11 RF 15
          LR 10 RR 15 Boubin Tire told me 15 on RR
          Chris Zogg
          • powerslide
            • 2696
            i think i would try reducing trail or stagger. and moving the jbar down 1in on each end.
            • washeduptoo
              • 1353
              Where is your jbar on the pinion again, I'm misunderstanding what you typed?
              • Flyin Iowan
                • 558
                about 1 1/4" about pinion on a QC
                Also would leaning the RR spring inward help with weight transfer?
                Chris Zogg
                • washeduptoo
                  • 1353
                  Try running 1in above center of pinion. Have you checked the lf shock to see if if is rebounding properly, had that problem a few times. Good luck.
                  • Flyin Iowan
                    • 558
                    shocks are all good. with the plate i have on the QC i would have to move it 1" so ill only be slightly above pinion
                    Chris Zogg
                    • washeduptoo
                      • 1353
                      Your talking above center of pinion correct? We've run ours at center and below on a qc with 6in of rake but that was too much rake, running a short panhard bar now and its working well for us. Good luck.
                      • 28m
                        • Dec 2010
                        • 49
                        What shocks are you running?
                        It seems obvious but you can do an 8-2 or 9-1 on the LR. Tie down shocks on the right side of the car...???
                        http://s200.photobucket.com/albums/a...8m%20and%201m/
                        • not clamped up
                          • 287
                          Do you have a brake floater on the LR ? It would help in traffic, Schrader has 1 on his car along with most everybody else thats fast,and when all else fails Z-link the Right side it won't be loose anymore,justa a couple other things you might think about.
                          • CHRISTINE
                            • Sep 2008
                            • 341
                            Z-link on rr
                            Are you leaving the spring in front on bc or putting it back on top?
                            • not clamped up
                              • 287
                              In front on the BC.
