less sidebite when tacky
  • Flyin Iowan
    • 558
    not looking for specifics to change so im not posting my setup. car has less side bite on entry and center and car tails out on exit. I stiffened rr spring 50lbs and it helped but car jumps cushion easily still...track isnt tacky often so just lookin for some suggestions. thanks
    Chris Zogg
  • washeduptoo
    • 1353
    I would mess with the jbar on the pinion or lower both ends if your trying to tighten up car. You could add some rear percent. Even up the rear trail/lead.Good luck.
    • clm15
      • Sep 2008
      • 390
      Try a tie down shock on RR like a 93,5 or 94,6. This will help a ton on a track with a cushion. Try a stiffer Lf spring and/or a stiffer comp LF shock.This will let the car on the RF witch will get the car on the RR faster and tighen entry.
      If you are on a pullbar,you can drop the j-bar on the pinion 1/4 at a time. The pullbar makes the j-bar rise when the driver gets back on the gas, I think thats why alot of mods get hung out in the mid corner and off.
      BUSTING OURS TO KICK YOURS
