I have a 07 hoffman car. I can get in the corner good with good side bite car is not tight turns in good and thru the center but it has no traction fron the apex to about 100 foot before the flag stand. From about the 100 foot before the flag stand to where i start decelerating the car is hooked up and a rocket! I roll into the throttle not busting the tires loose just little to no traction.
it is 4 bar LR floated spring behind shock in front. RR is 2 link spring on top shock behind. Chevelle clip. Springs are LF-550 RF-600 LR-175 RR-200. slick track integra gas shock package. spring progressive pullbar with a 600-1200 spring. pullbar is centered up on the rear end. ive got about 50 degrees upper lr angle at full extension. my lr lower is about 9 degrees at ride height and my rr link is about level at ride height. 4.5 inches of jbar rake. rear end side to side location is on what chassie manufacture specs call for. im just trying to figure out what to do to get some more side bite and traction from the center out....
