Looking for ways to get sidebite on a slick track with a driver who likes to drive in hard? Car just wants to slide and not stick.
Sidebite
What rear suspension is it and springs, shocks, just need more information. Sometimes slowing down is the only answer.
Easy up lt. frt. shock , easy down rt. frt. shock , suck rt. rr. wheel in , kick lt. rr. wheel out , cheat rearend over to the driver side , let lt. rr. chain limiter have more distance , drop rt. rr. lower bar , bump up rt. rr. spring rate .............
4 bar suspension. prefer not to give out much info just looking for general things to do with a driver that likes to drive in hard. This is on a higher banked momentum track if that makes any difference. Shocks are LF 5, RF 3-7, LR, 8-2, RR 3-4
Lower rear roll center. Use a left mounted wheel spacer.( i know there not cool) Raise rear of car.Raise ballast.
