ive took everything loose and i still have no drop and it is a 9in shock what to do
Need help!!! New to mods
Measure your rear end to frame rail at ride height. Put jack stands under frame and remove rear shocks and springs. Put jack under the middle of rear end and jack it up to your ride height. Move the rear end up and down on the right rear and left rear just like it travels as roll steer. If nothing is binding there check as you put your springs and shocks back on. Make sure to check your left rear shock drop. With a 9in shock you still may need a 1in or 2in extenion on your shock but make sure it does not bottom out when it drops off the bars. There is a sweet spot there. As for springs with a metric clip I would start out with 800LF 750 OR 700 RF 200 LR 175 RR. On the scales around 57.5 to 58 rear 52.5 53 left 49 49.5 cross on dry slick 75 or 80 lbs LR maybe even up to 120 or 130 LR. Good luck
one more thing are these %s with or with out driver and lr shock should it be mounted on inside top frame rail or out side top rail i have to diffrent mounts . Ones angled in toward center line. others outside up and down. and these are coilovers also if that matters
One time we mounted the 9010 in the wrong hole on tower bracket(too far to the back) and it wouldn't let rear end drop all the way as shock was extended out all the way. Good luck and I would still call Lighnting chassis or email to get basic set up.
It's a feel thing, some guys like it, some don't. But I would ditch it and see if thats whats keeping you from getting enough LR drop.
Driveshaft yoke too far in ????? (wheelbase,axle square,rearsteer) Birdcage timing and indexLast edited by 1Blacksheep; 08-31-2011, 08:07 PM.The Blacksheep cometh ! With old bent sh!t that just keeps getting faster !
