Pinto Spindles... Whats the advantage??
  • dirttrackrocker
    • Nov 2010
    • 664
    This has probably been covered a million times, but, I can't really find the answer. Whats the advantage of Pinto spindles over Impala, or metric?
  • usafracer
    • Jun 2010
    • 554
    The big advantage that I have noticed since switching to them is they are stronger. I would go through 3-4 metrics a year and I am still on the same set of Pintos.
    My sarcasm is a pre-emptive strike to your stupidity!!
    • AJ55
      • May 2011
      • 8
      They are lighter and easier to set up bump steer if they do not hit the lower A arms. I find metric spindles much stronger than pinto but that's just me. Bump steer is the big thing and the weight difference.
      • racin6mod
        • 2172
        plus with the pinto spindles you can run the hybrid rotors cutting a little more wt# of the front.
        • Gregory43
          • Jun 2010
          • 40
          I personally think the pinto's are stronger, and my steering is much quicker since i switched to them. Only problem i have had with them is that if i had the wheels turned all the way to the right the rf wheel would cut into my lower a-frame, but put a half inch wheel spacer on it and havent had any trouble since.
          • Reddy Powered
            • 176
            The few times I tried any wheel spacer bigger than 1/2" on RF it created inconsistency through turns. Could have just been because my setup didn't like it but it's something to look at if your car's handling is inconsistent.
            Steering is definitely quicker with Pinto spindles
            • C10
              • Nov 2008
              • 359
              Pinto spindles are nodular iron, so they are stronger and weigh a bit less.
