Pull Bar Mount
  • bpowell
    • Aug 2009
    • 69
    Pull Bar Mount
    Want to put a pull bar in my car over the winter,
    was wondering how far forward to have front mount from rear end?
    also has anyone ever put a pull bar on a Rocket chassis?
    and which pull bar assembly is the best/
    Thanks
  • not clamped up
    • 287
    pullbar and mount
    Have used this stuff on several cars.Speedway motors prices are as good as anywhere else.On the pullbar mount they also make it to fit a 9 inch ford.The front hole is 4 inches ahead of center line the back hole(if I remember right) is axle centerline.Brian Ruhlman builds a rocket modified and his new stuff has the pullbar option,thats who I would be callin.
    • dirttrackrocker
      • Nov 2010
      • 664
      There is no set rule that I know of for where the front pull bar mount should be on the chassis. Keep in mind that the longer the pull bar is, the longer it takes to hook up but, keeps traction longer. The shorter ones hook up quicker, but don't hold it as long.
      • hammond
        • 414
        I build pull bar mounts for both 9" fords and quick changes . My mounts have 28 holes for adjustment in them letting you go 2,3,4,5" in front of axle line .check out my website www.hammondmotorsports.com .
        http://www.facebook.com/#!/pages/Ham...26044754164488
        • dirttrackrocker
          • Nov 2010
          • 664
          Guys... Read the question. He asked about putting a pull bar mount on the chassis...
          • not clamped up
            • 287
            rocker you are correct I musta been pre occupied when I read that but I would give Ruhlman a call he may sell you what you need,personally I prefer the longer mount by the drive shaft loop.
            • bpowell
              • Aug 2009
              • 69
              Thanks for the info.i will give Ruhlmans a call.
              • latemodel61
                • Oct 2011
                • 10
                we sell lots of chassis mounts for mods and lates for pull bars, 4 link, etc. check us out at www.aa-mfg.com
                thanks. jim
