How to get the LF up???
  • dluna11w
    • May 2010
    • 81
    BOBRACING - I was going to mention something about adjusting wheel weights as well. Make certain that you are adjusting on all corners of the car and not just always the LR and RR, etc. I always get my ride heights as close as possible before putting the car on the scales. After that, the scales should really just be needed to set the LR bite in the car.
    • LM14
      • 490
      Why do you want to pick up the LF? Your car was built with 4 wheels for a reason, use them.
      More LR bar angle (up to 28*) and try to lose rear % and free up the car. Most people have their cars too tight.
      SPark
      • millerracing
        • Aug 2007
        • 72
        but it " Looks " cool with the lf hangin
        • millerracing
          • Aug 2007
          • 72
          lf431 rf549 lr644 rr470 is his scale numbers ? i normally dont see the Rf weighing more thank the Lf
          • boom 20
            • Apr 2009
            • 1
            ran a 1991 local built car in imca northern sport mod so no help so we played left rear bar 26degree up rr bar flat pull bar 30 some long and 20 degrees panhard 26 degrees mounted even w bottom of pinion 55 left 54.8 cross 55 rear 240lbs of bite would just hang lf coming off won points at one track 3rd at one and 4th at another
            • RACER88mod
              • 7
              Put about 55 lbs on the right side of the car up on the right side rail just inside of the nerf bar of the frame i couldent get my lf down and when i took the 55 lbs off fixed the problem hope it helps
              • bobracing32
                • Sep 2011
                • 10
                Thanks for all the input. I havent tried this setup yet. Hopefully in another week or two i will.hope for more info or input thanks
