My pull bar was mounted even with the centerline of my axle, I moved it 4 inches ahead on the rear end. What can I expect the first time I run it. I havent changes any thing else.
Moving pull bar ahead of axle center line
Its probably going to react quicker since you shortened pull bar and it might give you more forward bite as it gains angle as rear end wraps up. Good luck.
What that does is to keep angle in the upper link longer to promote a longer traction window. Anything out beyond four inches creates to much leverage and may not be beneficial.
Viewed from the drivers side, if 12:00 o'clock (center line) is where your pull bar is mounted and you're on the gas, it will go to one or two o'clock, going down. It will lower the center of gravity, less bite. If you have it in front of the axle center line, like you did, it will always be going up. The center of gravity will stay higher for more bite.Last edited by Dirtrunner35; 09-25-2011, 06:35 PM.
update post please
I'm curious on how this turned out so if you could update your findings, it's appreciated. I see this as Dirtrunner35 stated, the old way you have broken past the high point of the arch and moving down hill (1:00 or 2:00). Mounted up front, it would rise first, then try to break the top of the arch, if it ever does.
Not sure what the gain is or would be. but curious.
I've talked to other driver that tried and they both went back but that was with 9 inch floaters.I think ther could be a noticable change with a quick change rearend just due to the distance off the axle center line.here's a few photo's of different pull bar idea's
Okay 3 races into this and the car is really tight. In the center of the corner it just dosent transition and turn like it did before I moved it. Tight on entry, in the middle, and tight off. I moved the lb bar up to the top hole. entry is good. My chain is the same lenght it was but now it's pickin up the left front up pretty high. Gonna take a quarter inch out of it at a time until the left front tire is just skimming the top of the track then adjust fro there. Was lacking on forward bite on slick, got all the forward I need now, just gotta finish dialing her in.
