chevelle inner tie rod ends
  • JAMESGANGRACING
    • 192
    anyone know the part number for the short inner tie rod ends used on 68-72 chevelle with the longer bent tie rod tube?
  • BigBlueFord
    • 189
    Give Southwest Speed a call at: 479-646-6988
    They also have em with the grease zerk on the end instead of the back. Makes for a lot easier greasing.
    Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
    • outacontrol
      • 39
      I believe the short ones are Nova.
      http://www.inthepits.com
      • racer69
        • Apr 2009
        • 249
        Dave Hammond of Hammond Motorsports has what your hunting. He is on here so you might hunt the site a bit.
        • hammond
          • 414
          I make an inner tie rod that is bent so when you turn to the right it will clear the chassis better and then you run a std tie rod tube so you can adjust the toe with out having to remove the tie rod bolt and having to turn the heim joint
          www.hammondmotorsports.com
          http://www.facebook.com/#!/pages/Ham...26044754164488
          • cswitch11
            • 75
            Thanks for the info. I am on hunt of a site the manufactures tie rod ends. Can you suggest an online site where I can check car parts?
            • dirttrackrocker
              • Nov 2010
              • 664
              Good place to look up and cross reference parts. http://www.rockauto.com/
              • 6fan
                • Jan 2012
                • 11
                Moog # es323
