Pull Bar location
  • JDracing57
    • Apr 2008
    • 59
    Pull Bar location
    How high above the center line of the rear end should the rear of the pull bar be mounted?
    Thanks in advance
  • dirttrackrocker
    • Nov 2010
    • 664
    12" above axle centerline. Most are running the new afco mounts that put it 4" ahead also.
    • texas pride
      • Oct 2011
      • 62
      the new afoc brackets better for running a short pull bar or a longer pull bar
      • TCmod
        • Aug 2008
        • 94
        The new pull bar brackets are made at 12" above and 4" infront at -7* of pinion angle. Right foot performance sells weld on brackets for 9" and bolt on for quickchange.
        • latemodel61
          • Oct 2011
          • 10
          check out our pull bar brackets at www.aa-mfg.com
          we have them for 9" and quick change rears.
          • texas pride
            • Oct 2011
            • 62
            how does yall torque arm bracket mount its the weirds one ive seen?
