im putting together my first imca modifed and looking for some advice as far as setup for a four bar modified. i recently bought a bare metric chassis that a four link on both sides. in the front im going to run hybrid rotor,tubular lower A-frame,pinto spindles and springs i was thinking about a LF750 RF850 RR200 LR150 but not sure if thats the best springs setup looking for and advice ill being running on a 3/8 mile mostly and 1/4 mile track some. the rear suspension im running 4/4 bar with a j-bar and a regular long afco torque arm with a 1200 lb spring on it. i thinking about running a set of afco edge series shocks and i have a 9'' ford floater rear end with a 5/5 bolt pattern. So im looking for shock and spring location on the rear as well and what the best wheel off set to run. i hope this enough info for you to get idea at im trying to do. thanks for the help!!
setup help on a 4 bar modified
