06 pierce
  • darcy
    • Oct 2011
    • 31
    06 pierce
    needing set up sheets, can't get car to work right. don't have time to call pierce 12 hour work shift, hoping some one can help. thanks
  • millerracing
    • Aug 2007
    • 72
    assuming the car is tight ? could u post your scale numbers and what springs your running possibly ?
    • darcy
      • Oct 2011
      • 31
      no the car wants to spin sideways in the middle and it feels like it wont come off the corner. should i shorten the wheel base on the right or leave it alone. i'm in the neutral holes. pullbar is 1/4 " preload. 650s in the fronts 200s in the back
      52.6 left
      57.9 rear
      49 cross
      30lbs bite
      Thanks for any help
      • anissa5
        • Jul 2010
        • 79
        pierce
        I would try a 750 on the lf and 225 on lr and you may need the lower the left bottom bar. I also hope we can get some replys pierce may have some new clamp set-ups.
        • anissa5
          • Jul 2010
          • 79
          clamp
          You are clamped also are you on z-link rr or 4-bar
          • darcy
            • Oct 2011
            • 31
            I,m on z link now I did try the 4/4 and the car feels like it don't have no side bite. I've been seeing alot of cars on 4/4 clamped up lr spring on top rr.
            I would like to get a set up book from pierce but don't get off of work early enough to contact them. Any help would be good thanks.
            • millerracing
              • Aug 2007
              • 72
              shorten RR wheel base is a good start
              • anissa5
                • Jul 2010
                • 79
                wheelbase
                How much should you shorten the ride side
                • powerslide
                  • 2696
                  just try putting some more LR bite in it for now
                  • bob75
                    • 2814
                    how are you squaring the rear end up, also if no forward drive replace the pullbarspring (big problem). with those cars.
                    • JCSullivan00
                      • 1418
                      I came to ask the same thing as Bob75. Check your shock angles.
                      • millerracing
                        • Aug 2007
                        • 72
                        with the pierce car we had 20-25 pounds on the LR max it didnt like alot of LR - i know alot of it could be driver also just sayin
                        • pierce88
                          • Oct 2011
                          • 29
                          square the rear end up and dont go by the bars string over the axle tube and mesure to the frame forward. for side bite try some more spring in the RR. and a big deal the pull bar spring
                          need more help call me or bob75
                          • not clamped up
                            • 287
                            If you need more sidebite when the RR is 4 bar put the shock in front of the rearend instead of behind.And try a 225 in the LR next time both sides are 4 bar.
                            • anissa5
                              • Jul 2010
                              • 79
                              4-bar rr
                              Should the rr front shock be clamped on the 4-bar rr
