im new and need some help
  • robbie124
    • Sep 2011
    • 36
    hey guys im new to this forum and new to dirt racing.. i just came off 4 decent seasons dragracing and just thought id try somthing new.. i mostly have just ran big block chevy stuff so this small block stuff u dirt guys use are kinda new to me... i am in the process of building a 13.5:1 360 with a set of 23degree track 1 heads that have had some moderate port work done.. my question is what carb do u all recomend and what is involved in converting a drag race carb to a round track carb. i have a couple to choose from..holley 750 hp mechanical set up for drag racing and a holley 830 hp also a drag race carb.. thanks in advance
    robbie
    o yeah i will be running gas
  • jsf74
    • 544
    Just buy a new or used Holley hp and be done with it.
    • robbie124
      • Sep 2011
      • 36
      Thax for the reply but I don't like to buy used carbs unless I see them ran and its kinda hard to do that this time a year I was wanting to convert the 750 HP I have to make it work for round track I am pretty sure that it won't need the jet exstensions in the back any more but like I said I don't have a clue a bout round track yet.
      • powerslide
        • 2696
        If you are converting one i would call a good builder they will know what all needs changed. i would bet the floats need to be diff not sure what else. KB, Willys, Braswell should all be able to tell you what needs done. Smaller shops Larrys carb in oklahoma and then kinetic performance could probably help you out as well.
        • smirk
          • 60
          Slow down the linkage, floats, get rid of jet extensions. Make sure correct power valves
          • robbie124
            • Sep 2011
            • 36
            thanks for the help
            • dlm82
              • 214
              send your carb to karsten at KB carbs. he has a drag racing background. I am sure he can rework your carb and save a little change!!
