needing set up help
  • Rfisher23
    • Jul 2011
    • 41
    needing set up help
    I have a 2001 fastlane chassis 4 bar car, just bought the car, needing some help on what lbs front springs and rear springs is a ok starting point, and also what kind of off set wheels should i be using all around??? thanks alot!!
  • Rfisher23
    • Jul 2011
    • 41
    also what is a good starting point for cross and weight, thanks alot
    • washeduptoo
      • 1353
      Never heard of them but what front clip is it and might could offer suggestions.
      • Rfisher23
        • Jul 2011
        • 41
        Metric
        Metric clip
        • dirttrackrocker
          • Nov 2010
          • 664
          Is it Metric with Metric lowers or Nova? The common mistake with Metric lowers is, everyone wants to use light springs like a Chevelle. Heres some basic info to help you.
          Chevelle lowers have a 36% ratio
          Nova Lowers have a 30% ratio
          Metric lowers have a 23% ratio
          Meaning that if you use a 650# spring on a Chevelle lower 650 x 36% = 234# at the ball joint.
          To get the same with a Metric lower you need to use a 1000# spring 1000 x 23% = 230.
          Metrics also don't have near the travel ability, so if you try to use a softer spring, they bottom out quicker and will push like a dump truck.
          From my experience with my metric, I would start with a 1050 in the RF and 950-1000 in LF. 2" off sets on all except RR. Use a 3" or 4" on the RR.
          As for rear springs, start with 175# across the back with 30-40# of LR bite.
          • Rfisher23
            • Jul 2011
            • 41
            ok cool thanks alot, just trying to get started out, new to dirt racing, thanks alot
