X factor pull bar
  • Hagen14t
    • May 2011
    • 167
    X factor pull bar
    I have an x factor pull bar with the black bushing and the red brake bushing. I just have a couple questions to ask. When you put preload into the brake bushing does it also put preload into the black bushing? And how much preload should be put into each bushing?
  • Hagen14t
    • May 2011
    • 167
    I put the 1050 bushing in, but how do you set the preload into these? The nut that holds the back of the bushing in? Just wondering because that is only threaded a little ways and then it turns into the shaft. So do you use that nut to set preload or use the brake bushing one to set the preload into it?
    • CHRISTINE
      • Sep 2008
      • 341
      Pull bar
      Yeah you tighten up the nut on the back of big bushing or the one in front of the brake bushing they both do the same thing since its all on one shaft. Try not to get to much grease on the bushing or it will pull the big washer thru it. Had that happen last year.
