looking for 2 link advise.
  • xxx8x
    • Jan 2010
    • 15
    07 dw11 2010 scotty allen front end rear clip updates.looking for ideas and info to better me and car. frame heights lf 6 rf 5 7/8 lr 7 3/8 rr 7 1/4 tire press lf 9 rf 14 lr 9 rr 12. springs lf 650 rf 700 lr 200 rr 200. shocks lf pro 74 rf pro 3-5 lr bilstein 2-6 rr pro 3-5. wheel base right side long 1/2. 1/4 toe out. front end lf +2caster +1 1/2 camber rf +4caster split -3 3/4 camber. solid pull bar, pan hard bar in front center of pinion 4in of rake. rear springs on top, can put spring on lr in front if better. rear pinion angle 6. scale out numbers ls%52 cross 47% rear % 57 bite 44 right rear. looking for advise on lr vs rr bite? go for it guys and gals let me know what im doing good or bad. like to be better on and off the track.
  • washeduptoo
    • 1353
    If Scotty done the updates, I'd give him a call and get some specs. 417-993-1666, leave a message if he doesn't answer. I have some 04 set up for 2link if you need them but Scotty would have the updated information.
    • xxx8x
      • Jan 2010
      • 15
      got set up info from scotty just wanting to know other ideas from what we are doing. like if guys like rr bite vs lr bite. lr spring in front or back, if my shock # look good. eney info apprecated. hearing alot of diffrent things. seems like advise on 4m a guy can get will help or open your mind to new things.
      • washeduptoo
        • 1353
        Can you run a spring or biscuit pull bar? Those ride hts must be no driver? You must not be running IMCA if you can run spring in front and panhard in front? He has some very fast guys that run the 2 link B-mod, is that what your running rules wise?
        • xxx8x
          • Jan 2010
          • 15
          Yeah we run sold pull bars, no springs or bisquit bars. frame heights without driver,kk704 tire rule. with 602 crate.there is several guys in area say rr bite, new car for me got 1 good night in car.like to try lr spring in front, and maybe lr bite.just dont get much test time.
