Will a 7" tall Hypercoil prog spring work in the new AFCO 3 stage torque link? They say to use a 6 5/8" tall spring.
Prog. Pull Bar Spring
Pull Bar Spring
We have the 7 inch progressive on our car and it works/fits. Make sure the JBar does not contact the pullbar as the progressive spring is bigger around than the straight rate springs, at least ours is. Also lock tight all the nuts and bolts on the 3 way again.
That thing has a tendency to come loose. Last thing turn the rubber bumpers all the way in to have the max clearance until you see how much travel you have, the progressive moves more. We took our rubber bumpers out
JohnLast edited by Darkstar15; 12-16-2010, 08:30 AM.
