Foam in fuel cell for alcohol
  • modracer47
    • Nov 2011
    • 14
    Getting back into modified racing, after a few years off and have always used racing fuel, but will be using alcohol.
    I noticed there is foam for alcohol, to put in the fuel cell, but would like to know pros and/or cons.
    Appreciate your input.
    Thanks.
  • dirttrackrocker
    • Nov 2010
    • 664
    I have always heard not to use foam with alcohol because it breaks down. Pack it with wiffle balls instead. They work great as a baffle, you can buy them in bulk from some of the sports stores.
    • Racer111
      • 796
      Never seen anything good come out of useing foam..
      • JustAddDirt
        • 1893
        foam
        I woud not use foam with ALKY it will break the foam down and plug up the fuel system.
        I have heard of black perferated drain tile cut to the correct height and fill the cell up. acts as baffles.
        • Kojak_9x
          • 179
          Foam for alky in a 32 gal fuel cell ran me $240 a few years back. Only ran it a few times before I sold the car. I wouldnt buy it again cause of the price. Stick with drain tile, wiffel balls, or even pvc pipe(drill holes and "V" notch the bottoms. The last few years I haven't ran anything....
          • modracer47
            • Nov 2011
            • 14
            Appreciate the input.
            • dirttrackrocker
              • Nov 2010
              • 664
              I went to using nothing as well. Anything you use is gonna take up space, and in a long race, that may be the difference in making it and running out.
              • moparacer
                • 2
                Wiffle balls is a great tip. Thanks
                • dirttrackrocker
                  • Nov 2010
                  • 664
                  Make sure you drill a hole in one and put your pick up hose inside it so it doesn't suck tight to the outside of one of the balls...
