Difference between Dirtworks DW8, DW9 Chassis
  • 15jr
    • Feb 2009
    • 482
    Just curious if anyone can tell me the differences between the Dirtworks DW8,DW9 chassis? I know they use a different upper Aframe but not quite sure after that.
  • cassellracing24
    • Aug 2007
    • 497
    They both follow a Pierce....... =)
    Central IL Bert Transmission Rebuilder
    Brian (217)201-3640
    • 15jr
      • Feb 2009
      • 482
      How did I know you would be responding to my post! LOL
      • LM14
        • 490
        We had a DW9 for a couple years. When I talked to DirtWorks about it, they said it was stiffer than other chassis they built and would respond to smaller spring changes and adjustments. I think they seem less forgiving on setup errors. The upper a-frame ball joint holders fit either side so you don't need right/left specific ball joint holders.
        JMO,
        SPark
        • 15jr
          • Feb 2009
          • 482
          JMO,
          SPark
          Interesting. Thanks for the feedback. That is the last way I thought they would be different. I expected suspension setup would be the difference or maybe front clip work.
          • JHobbs26
            • Aug 2007
            • 146
            a lot of guys are cutting the bar out of the RF corner of the main cage that connects the upper frame rail to the top of the hoop. This lets the frame flex so its a little more forgiving.
