Hey guys i was just wondering what the best way to measure trail. Ive never really seen it done so i was just wondering how to do it and what the best option is. ??
Measuring trail
I don't know much about alignment racks, but I assume they use the position of the front wheels to align the rear axle. I'm probably wrong.
One thing I've noticed is, on a modiied is you can't rely on both front wheels being in the same location. Frame turning or manipulation can make the right front set farther forward than the left front.
There's one thing I've done on a modified that doesn't have refererance marks on the rear stub. The upper bar behind the seat, running left to right that the upper tail bar comes off of is a good place to start, because it's usually square with the frame. When I do this, I take the rear wheels off and support the rearend in a manner that leaves the car at proper ride height. Start on one side and hang a plum bob from the upper tail down to the rearend. Measure from the string on the upper tail bar to the bar behind the seat. Do the same thing on the opposite side, and you'll be able to see how much or how little trail you have. You should be able to use this method to put reference marks on your upper tail bars to make it easier next time.
They will tell you how much set back the front and the rear has, wheel base on both sides and rear axle offset. A garage might not charge that much just to check it, about ten min worth.
I pretty sure you can't measure that Allen from ball jts, front stub is turned. We built some blocks out of wood for 4 corners and put the car on them. We use a big square and go from floor on one edge and the other edge on axled tube. Then a tape measure to back on square against rear end from bar behind seat that we set ride hts with. Maybe this will help.
If the cars built with trail then you can go by that. If the cars built with 1/2" of trail and you have your right side bars set an 1/8" longer than you'll have 5/8" trail. Find how much is built into the car first then figure it out. Call your chassis builder.
And measure from a point on the chassis that is the same distance from the front tires like a 4 bar brackets mount tubing.
Stock car driver hit it on the head, the mid plate should be square to the world. If not something is probably drastically wrong. Drop plumb bobs off the mid plate and measure to the reaerend.
I know you can measure mid plate to right side of rearend, but how do you do the left side? Also, the mid plate is narrow, you want a measurement as close to the hub as possible.
Take a string and a bolt tie the string to the bolt.Drop the bolt over the axle tube, put it out as far as you can to the tire,and in line with the lower balljoints. (Bolt cant hit the floor) DA!
Take the grease zerts out of the balljoints.Find a new or old set of grease zerts. drill the ball and spring out with a 1/8th in drillbit. run some string through the zert. Tie a bolt to the string,screw them in by hand,measure the distance from string to string.
Over the last few years,Builders have been turning the front clips to make the rf longer. Check with the builder for the proper distance. Goodluck have fun.BUSTING OURS TO KICK YOURS
I pull the door and qtr tin off the left side and clamp a piece of angle or strap to the midplate at an angle so that it is in line with the rear end tube closest to the outside of the tube. Have someone hold the tape or just hook it to the strap or angle. Add or subtract as needed depending on the strap or angle being clamped on the front or back of the midplate. That is how i do it and it works for me. I also do the right side off the mid plate. After i get rear end where it needs to be i use a spot on the frame on both sides where the 4 bar brackets are mounted and measure to the front of the rear end tube from then on, unless the car gets a hard hit. jmo.
Thats fine if you have a new car,or if you know if its not bent. .But if its a used car? It could have a bent a- frame or most anything. Stock a frames look ok sometimes but can be bent. I have seen cars that teams set the 4bar rods wrong ect. The string dont lie.BUSTING OURS TO KICK YOURS
That's why i measure from the midplate as there can be a bent a arm or slight frame damage that can't be seen. Also my rf stub has been turned. Measuring from the midplate is the only way to be sure. imo.
