Ok my mod has a clamped LR noone around my track knows nothing bout a clamped car. Where should the shocks and springs me mounted. Left side spring in front or behind? Right side spring infront or behind? Whats some advantages of a clamped LR or any? And this is a 4 bar 4 bar car
clamped LR help me out
The LR spring has to be in front on a clamp. The cars I have seen running clamped up have the right spring on top of the axle tube, but, I'm sure you could run it in front also.Originally posted by bluemod View PostOk my mod has a clamped LR noone around my track knows nothing bout a clamped car. Where should the shocks and springs me mounted. Left side spring in front or behind? Right side spring infront or behind? Whats some advantages of a clamped LR or any? And this is a 4 bar 4 bar car
I always run my springs in front on both sides the only time the rr spring on top of the axle seems to work is on the z link rr set up it make the car seem loose and darty on the 4 bar set up.I run the lr spring with a coil over kit on a clamp bracket and the rr on a slider floated on the bc with the shock mounted behind the axle this makes it realy easy to tune at the track and I've do it with my chassis and my brothers dw9 chassis it hooks up hard coming out.Last edited by racin6mod; 01-01-2012, 05:14 PM.
Racin6mod seems to have this right. I've run the RR spring in front on a swing arm, on a birdcage (with a coil kit or eliminator) and on the tube. I prefer the spring on the birdcage with an eliminator and the shock behind on a bracket. Seems to be more consistent. My beef with the RR spring on the tube is that car turns too easy for my preference and is inconsistent when the track condition changes.
It doesn't matter if it's 4/4 or 4/zlink. Run the rr spring on top of the rearend and put the lr spring in front on a clamp bracket. Take your c/o eliminators and sell them. These cars work much better with just the springs in spring buckets. Run about 40# of lr and you should be close.
Clamped up is good for straight line drive but they have a throttle tight tendency.Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
