shaw midwest modified
  • jimmy338303
    • Jun 2008
    • 17
    I WAS LOOKING AT THE LARRY SHAW RACECARS WEBSITE AND SAW THE MIDWEST MODIFIED REAR SUSPENSION SETUP. i dont have a shaw car but we have decided to try the spring with buckets on the swingarm. The problem we are having is when we let the car down the weight buckles the spring. If anyone has any ideas on how to solve this problem any recommendations would be great. I have a feeling it could be because we are using a 16in. spring but not sure. by buckling i mean the spring gets bent sideways instead of standing straight up and down
  • dualdj1
    • Jun 2009
    • 654
    what weight of spring are you using? Also yes, the 16 is probably too long. in their pictures that looks like around a 12, maybe 14"
    • jimmy338303
      • Jun 2008
      • 17
      thank you for the reply we appreciate it it is a 250
      • dualdj1
        • Jun 2009
        • 654
        don't know the chassis, so i can't say for sure, but that seems awfully light, especially at that length. did you contact shaw to see what they recommend? I don't think we ever ran under 350 on swingarm on our LM, and that was 12 or 14".
        • racing24
          • May 2011
          • 12
          if your aloud to run sliders that would cure the problem thats how i have my shaw mwm
          • Sroufe7
            • Feb 2010
            • 7
            I don't have a shaw, but I ran 225 on the RR and 275 # on the LR last year on the swing arms.
            • JustAddDirt
              • 1893
              swinger
              What is the motion ratio of the swingarms?
              In my experiance most people are way too light on the springs on the swing arm stuff.
              I had a 50% ratio on a lightning and was running a 400 LR and a 375RR
              which turned out to be a 200LR and a 187RR with the motion ratio factored in.
              Also people who use a coilover on the swing arm go way too light on shock valving.
              • racing24
                • May 2011
                • 12
                when i talked to kevin shaw about mine he recomended 300 and 350 in the rear
