How to set pinion angle with a quick change rear?
  • missile07
    • Aug 2007
    • 680
    Looking for the proper way to set the pinion on a mod with a quick change?
  • Egoracing
    • 4852
    Lift arm or pull bar?
    • BigBlueFord
      • 189
      J-bar pinion plate
      Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
      • LM14
        • 490
        Difference between driveshaft angle and rearend vertical angle. Doesn't matter what type of rearend it is. For a reference on a QC, you can use the j-bar plate as stated above or the rearenc cover ribs.
        SPark
        • missile07
          • Aug 2007
          • 680
          Pull bar....A guy told me a couple of years back a way of doing it off of the back cover plate and subtracting the angle from 90 degrees....or something like that????
          • PIERCE3J
            • Jan 2011
            • 55
            LM 14 is right. Difference between the driveshaft angle and the rearend angle gives a total angle of pinion degrees. Measured at ride height.
            • missile07
              • Aug 2007
              • 680
              But where do you place the angle finder at on the pinion? The j-bar mount? Anyone know of the method of measuring from the back cover plate?
              • powerslide
                • 2696
                You do it just like you did on your 9in the other side of the pinion plate. Or like they said you can use the back side of the gear cover because its flat to the pinion. I lay mine across the nuts that actually hold the cover on.
