Measure from the ground to the center of the bottom a arm bolt on the front. And then from the top of the rear end housing to the bottom of the 1 3/4 pipe on the back.
DW-11's dont have 1-3/4" tubing on the back. It is 2" and the correct measurements is from the 2x3 rectangular tubing in the back on the bottom of frame and front measurements are off the large hole on the kickouts. Stick the tape measure through the hole and measure at the lowest spot.
