Lr brake floater pros and cons
  • roundboy
    • Nov 2011
    • 68
    4-bar both sides, both brakes clamped right now, what would the advantage be to float the lr??? Any help is greatly apreciated... thanks in advance....
  • TeamGRT12x
    • 911
    First, you'll want to dedicate half a season to getting used to driving with the floater. If you don't like it, just take all the angle out of the floater bar.
    Second, you'll have to work on chassis setups to get the car to work with the floater. Sometimes, the setup you run works fine with the floater, other times you'll be way too tight.
    If you find yourself riding the brakes a lot right now, you should be ok. Just remember that you can manipulate the race car many different ways with that floater on there.
    Advantages VS Clamped up... I don't see it being a game changer anymore. The cars work good enough that you can go just as fast without one.
    Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
    • Darkstar15
      • 90
      LR floater
      Agree with GRT12X. Our driver likes car both ways. Uses floater more when on short tracks. Otherwise we flatten out floater bar.
      John
      • roundboy
        • Nov 2011
        • 68
        Thanks for the info... think ill save a few bucks and leave well enough alone....
        • jsf74
          • 544
          So if the floater bar is parallel to the ground it donesnt affect the chassis? It seems with the range of motion the floater will affect it no matter what?
          • TeamGRT12x
            • 911
            With it flat it has a lot less influence on the chassis.
            • fojtik83
              • Apr 2009
              • 306
              If your looking to try one I have one for sale for $80. It's a BSB bearing floater not ran very much at all.
