Spring in front/Shock behind on Right Rear
  • Darkstar15
    • 90
    Just did this change to our car. Went to practice, was tacky. Car ran ok, but wanted to lift left front when driver got back in gas. Not too high, maybe 6 to 8 inchs. Did not carry it very far either. Car did not do this last year with spring and shock togrther. Not sure we were ever on a track this tacky last year though. Question is, is this normal ? The other mods were not doing this. Not sure we like this. It sure seems he was over on the RR alots.
    John
  • johnny v
    • Mar 2011
    • 197
    what's the angle on the RRU bar?
    Raise it up 1 hole... that should lay the LF back down...
    see ya
    johnny v
    • Dirtrunner35
      • May 2010
      • 632
      A stop watch will tell you if it was hurting you.
      • k.shaw
        • Oct 2008
        • 154
        I like having the shock on back, If their was a lot of traction in the track either raise the
        RR Upper link on the chassis or stiffen the RR spring.
        Kevin Shaw
        • CHRISTINE
          • Sep 2008
          • 341
          spring
          Kevin what does this do to the car? what adjustments should be made when the track drys?
          • k.shaw
            • Oct 2008
            • 154
            When the shock is behind it will slow the shaft speed down and not ramp up the rate of the
            shock compression as much as if it were in the front. Both ways work well, I just prefer the shock behind.
            As far as making changes as with the start of the post ,I think the car would have been fine in the slick you just have to tune this setup more so in the traction.
            Kevin Shaw
            • racin6mod
              • 2172
              I deleted my earlier post I mes read the question.I was thinking of a builder that puts the spring behind on the rr using a coilover set up.
              I like the spring in front on the bird cage with a standard valve shock behind on the rr just seems to have a better fill.
              • CHRISTINE
                • Sep 2008
                • 341
                Shocks
                Thats my next question should you use the same 3-5 shock or a 93 or a 3-7 ???? on this set up
