quick change gear help
  • Deish98
    • Jan 2012
    • 238
    wat gear would work on a three eighths track.... i have 08 shaw with a 406 chevy small block...rpms i would want 2 b around 8500.... and its a winters quick change
  • oldtrackchamp4x
    • 270
    First thing to do is check and make sure your cam curve does not "stop" or flatten out before 8500. If the curve looks good, probably run 620-633. JMO
    • LKissinger8
      • May 2008
      • 87
      If you are referring to flora I'd venture to say you should start out around a 5.83 and adjust from there
      • Graff Spee
        • 881
        Just remember that as a rule of thumb that every ten numbers gets you 100 rpm! Food for thought.
