Right rear spring height
  • modman1010
    • Mar 2012
    • 30
    What is the difference in let's say a 16 inch 225lb spring and a 13 inch 225lb spring? Does it really matter the height of the spring on the right rear?
  • Flyin Iowan
    • 558
    ones taller then the other. say the rr corner weighs 225lbs both springs would be compressed 1". the idea of a taller spring is so you can go softer and still have room so it wont coil bind. i know some do that on the lr but havnt heard of any doing this on the rr.
    just my opinion
    Chris Zogg
    • washeduptoo
      • 1353
      It also depends upon where you run the spring, I don't think a 16in spring will fit on top of axle tube. Just something to think about.
      • racinjj
        • 98
        Chris is spot on, the free hieght of the spring does not affect its rate or performance. I would use the shortest springs you can get away with and not coil bind, the extra hieght just adds extra weight.
        www.UltimateRaceCars.com
        • Dirtrunner35
          • May 2010
          • 632
          16 to a 13 inch spring will let the car roll over more since the spring is shorter
          • JR. MECHANIC
            • 253
            Dirtrunner, does it matter if it's on a coil over or just on a weight Jack bolt?
            • DaveBauerSS6
              • Jun 2010
              • 566
              The top of a spring is the spring table. Keeping the center of gravity the same and the spring rate the same, lowering the roll table will allow the car to roll easier. Center of gravity pivots to the roll table. Makes a big difference.
              Gator Engineering
              • Flyin Iowan
                • 558
                the top of the spring is the table? why wouldnt it be where the coil over bolts to the frame?
                plus every car i have seen in my area run the coil over upside down on the rr so no matter what spring its the same at the top
                Chris Zogg
                  • 14324
                  On a coilover, the attachment point of the coilover is what matters. You are correct. If the spring is sitting on the axle, in pockets, then yes height matters.
                  • racinjj
                    • 98
                    I was reffereing to coil over/sliders, on top of the housing is a different story.
                    • powerslide
                      • 2696
                      seems to be some confusion.
                      If the spring is on a coil over the two mounting points matter. Spring height makes no difference. one may bow more than the other and weigh a little more but thats it
                      If the springs is on a weight jack bolt the height of the top spring cup is extremely important and need to confirm w/ chassis builder which spring height you use. If you get it to tall of a spring the weight may not be able to get on top of the spring. Get it too low and it may get on top of it too much.
                      • DaveBauerSS6
                        • Jun 2010
                        • 566
                        I assumed the question was for screw jacks. Jacks are at the top of the spring, coil overs are at the top mount bolt.
                        Yes you can lower the roll table by lowering the upper coil over mount. This may require lowering the bottom mount. Be careful on your birdcage indexing.
                        Gator Engineering
                        • Dirtrunner35
                          • May 2010
                          • 632
                          It doesn't matter, the bottom of the spring will always be the same, static weight will be the same, only difference is the shorter spring will let the car roll over more, like someone said bird indexing will be more, rear steer. Total weight transfer will not change but front to back weight transfer will change some.
                          • missile07
                            • Aug 2007
                            • 680
                            Ok quick question for better understanding. Say you have a shock with spring mounted in front of the axle on the RR. Does it matter which way the shock is located? Some have the bulb area of the shock at the top with locates the spring lower and some have the shock upside down and moves the spring higher.
                              • 14324
                              There is some difference in unsprung weight. For the purposes of the spring, it does not matter. The location of your spring's attachment point is all that matters. The height of the spring is only important if changing it changes it's connection point to the chassis.
                              On a coilover, you can run a 14", 12", 10" spring and as long as you keep running the adjuster nut down to compensate it doesn't matter. It matters with a spring mounted on the axle with a jack bolt because you must run the jack bolt down to compensate. This lowers the springs interaction point with the chassis. It is the same as cutting off a coilover mount and spacing it down.
