Left rear chain question
  • missile07
    • Aug 2007
    • 680
    When using a chain on the left rear should the mounting point on the axle be clamped down or free to swivel/rotate?
    Also same question for the right rear?
  • JustAddDirt
    • 1893
    chain.
    Either will work. If u use a standard clamp, snug it up, but not really tight, and it will find its home. Run it 1 time, and it should rotate it to were the clamp needs to be, then tighten up tight.
    • Graff Spee
      • 881
      I like using a cable but if you are really using a chain, you should wrap tape around it so that it doesnt get kinked and jam up.
      • charcoal01
        • 545
        What if you can't float the brackets? Ls in front rs on top?
