I have a metric clip with nova lowers using a 650 RF spring, 4/6 shock, 600 LF spring 5/3 shock. LR 7/2 shock in front, 200 spring in back on a slider 4 bar floated. RR 3 link set up clamped. Rod is at about 5 degrees up. 200 spring on top and 94 shock behind rear end. I'm using a shorty bar at pinion and 3 inches of rake to the frame. There is about a 1/4 inch of lead in the RR. The car wont turn enough when i enter the corner. It can be very unpredictable because once i DO get it to turn
(if it doesn't push) it doesn't give me the bite i need till i get straight. See any thing i can do to help this ?
