Shaw Carrying LF down straight away
  • Sparkmaker
    • Nov 2011
    • 31
    Running a 200lb spring on RR , really getting on RR and carrying LF tire. 94 shock with about 75lbs gas, not alot of jbar angle . Anybody running more than a 200lb spring on RR?
  • TeamGRT12x
    • 911
    Sounds like you may want to limit the LR Drop a little more. How much drop do you have currently? Sometimes too, too much Upper LR Bar angle will rock the car over in a straight line.
    Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
    • k.shaw
      • Oct 2008
      • 154
      The LR chain drop could be too much it needs to be 15 3/4 in. from top of Birdcage to bottom of frame rail when the chain is tight.
      You also may want to raise the RR upper link on the chassis .
      Also a 20 to 30 Lb piece of ballast on the LF would also help.
      Thanks Kevin Shaw
