Drive shaft?
  • Racer7R
    • May 2011
    • 28
    Drive shaft?
    Does anyone know where I can get a drive shaft shortened in the Ashland, Ky./Huntington, WV area? I need to take an inch off.
    Thanks for any help.
  • crateracer16
    • Apr 2009
    • 332
    How long do you need it to be?
    • dirttrackrocker
      • Nov 2010
      • 664
      If you have the long yoke, just find a machine shop and have them put the yoke in a lathe and take an inch off.
      • Racer7R
        • May 2011
        • 28
        The yoke is fine. I actually need the shaft itself shortened. I only have about a half inch of yoke sticking out of the tail shaft at ride height.
        • racin6mod
          • 2172
          if this is for the mono leaf car you posted about earlier if it has a 9 inch rearend you might be able to get a shorter pinion yoke. just trimming an inch out of the drive shaft may cost more than just buying a used drive shaft that's the correct length. I charge $50 here in western il. to shorten a shaft.
