Lightning from 2-link to 4 on left
  • racer69
    • Apr 2009
    • 249
    Got an 06 Lightning with (I was told) 09 updates. Its set-up 2-link but I wanna try to go to 4 bar on the left. What angles should they be at? Mainly upper bar.
    Don you make a great car and after reversing the previous 1 year owner's very bad adjustments this thing has come to life! I just need a little more!
    Thanks in advance,
    Junior Payton
  • JustAddDirt
    • 1893
    upper link
    do not go over 45 degrees at full drop of suspension on LR. ( that is how I set mine is full drop, do not much worry about the starting angle (based on the correct drop on LR)
    Is this an under rail car?
    If you are on a pullbar go one hole above level on bottom bar.
    That should get you a good starting point
    • HEAVY DUTY
      • 796
      Check your number on the chassis. I am not aware of any 06 cars with a 2 link.There are some older 2 link stuff out there like 98 or 99.Without knowing exactly what year of car you have it is hard to tell you what to do.There is major differences between 04 an 05 and up chassis.
      • racer69
        • Apr 2009
        • 249
        Thanks guys. Don hooked me up.
