needing forward bite...help please
  • bluemod
    • 214
    Ok took car out and its a little loose but feels pretty good. Coming off the corner it feels like it needs more forward bite. Whats the best way to get forward bite and not mess the car up in any other way? Thanks for the help in advance
  • dirttrackrocker
    • Nov 2010
    • 664
    Raise both upper bars on the rear.
    • TeamGRT12x
      • 911
      Before you start adjusting and cranking on stuff, does it "feel" like it needs forward bite or do you "think" it needs more forward drive. Are you getting pulled on corner exit?
      If so, it could be as simple as indexing the left rear birdcage a little more into the spring. If it is rotating mid corner well (Not loose, not tight) that is where I would start. If you're loose on throttle, I would drop the left lower down one hole and see where it gets you. Just try not to get the car too tight in the middle or you'll kill exit no matter how much drive you have.
      • bluemod
        • 214
        sorry im lookin for more forward drive off the corner the car is good everywhere just lookin for a little more drive off
        • Flyin Iowan
          • 558
          Are you on a pull bar? If you have a 3 way bar i would adjust the rubbers inside to come in a little quicker. I try to have my bar as close to solid as possible by the time im getting straight out of the corner
          Chris Zogg
          • Hagen14t
            • May 2011
            • 167
            Woudnt you wanna raise the left upper and drop the right upper? Or why would you raise both bars?
            • bluemod
              • 214
              im on a pull bar i have it ajusted in a 1/4 its not new. its black with 5 rubbers. And my lrb is all the way up and rrb is one hole from the top
              • bluemod
                • 214
                my pull bar is 42in long and mounted to the drive shaft loop bout 3 hole up
                • HEAVY DUTY
                  • 796
                  Are you clamped or spring behind? Sounds like you have one of my older cars. Have you put fresh biscuits in the pullbar lately? They need to be changed at 10 or 15 nights. Too much panhard bar angle can hurt late exit also.
                  • bluemod
                    • 214
                    i now have spring behind lr.I have it on coilovers. i have no clue when the bushings were changed. im not for sure what i even need to buy for this pull bar.
                    • washeduptoo
                      • 1353
                      You could try dropping the pull bar on the frame to see if thats what it needs. Good luck.
                      • LM14
                        • 490
                        Don't change a bar until you freshen that pull bar.
                        SPark
                        • bluemod
                          • 214
                          is there a good pull bar to go with or what to go with to referb.
                          • Dirtrunner35
                            • May 2010
                            • 632
                            less rear steer
