Okay lets say that the line during a feature is you have to go into the corner in the middle and get the car to turn enough to come out of the corner right on the bottom. What the best way to cure a slight push in the middle. Its not even a push, just need the car to rotate just a little bit better. What would be the right area of the car to look at?
Cutting in the middle
cut
LR bottom bar up one hole. Should put a hint of steer in it, and a bit of traction.
All replies will be different, so you will probably have several options from alot of people.I think there should be lifeguards in the genepool.
Soften LF or stiffen RF (adds wedge) or just add wedge, or less rear % or add left %, add some trail (static steer)or (bar angles dynamic steer).The Blacksheep cometh ! With old bent sh!t that just keeps getting faster !
all of these suggestions are good , one other that was not mentioned but I like is pulling the Left rear tire under the car a little more. If your using a 2 in. offset wheel go to a 3 in. offset. Or whatever your using go to a deeper offset.
Thanks Kevin
