Tighten 4bar car up on entry
  • CHRISTINE
    • Sep 2008
    • 341
    If you roll in off the gas do you still soften rf and or stiffen lf to tighten car? Or is it different since your not in the gas?
  • dirtnasty5r
    • Apr 2012
    • 3
    Adjust your right lower for corner entry. If it is to loose on entry. move your right lower down. If to tight move your right lower up.
    • kraftkar7x
      • Apr 2009
      • 147
      Stiffer lf spring will tighten you up on entry
      • TeamGRT12x
        • 911
        Stiffen the left front by 50 pounds as said earlier. If you feel the front end is good, and cutting well, I'd try to strap the back end down by putting a little more J Bar angle in it or pulling the RR Wheel in an inch.
        There are a variety of other changes you can try, but I'd start there. The others are going to effect exit.
