Sportmod trailing arm questions
  • Sportmod Rookie
    • May 2012
    • 60
    Im new to sportmods. I have some questions on the effects of moving the trailing arm. If I move the trailing arm up or down on the frame how does it effect the car? Will the change only help under acceleration? Any info will help. Right now my car pushes on corner entry. Which bar should I move?
  • dirttrackrocker
    • Nov 2010
    • 664
    Up at the chassis puts more roll steer in the car
    • burnerdaddy
      • Apr 2011
      • 27
      Need to kno more whats your scale numbers and bar location now
      • Sportmod Rookie
        • May 2012
        • 60
        Even on the right side it puts more roll steer? I was looking at a post on a different forum but he had the same problem. Push on entry. He had his right side bar to the top hole. Someone told him to lower the right side. Is that bad info? I will post my scale weights when I get home. I run IMCA northern sportmod.
        • racinjj
          • 98
          Assuming you have an IMCA type 3 link:
          With the lack of horsepower and rear suspension adjustment sportmods tend to be very tight if not setup correctly. The biggest thing I can tell you is take rear weight out of your car get down to at most 54% full of fuel. In general adding trailing arm angle to either side will increase roll steer. However either side effects things differently beyond the roll steer effect.
          Lowering the right side bar will make your problems worse.
          www.UltimateRaceCars.com
          • Sportmod Rookie
            • May 2012
            • 60
            Right now I have a 650 LF 650 RF 200 LR 175 RR. I have seen on setup sheets online that a stiffer RF spring will help loosen the car on entry but I have also seen setup sheets say go softer on front springs. Thoughts?
            • dirttrackrocker
              • Nov 2010
              • 664
              Lots of things you can do. More stagger, trail RR, More rear brake, stiffen LF
              • washeduptoo
                • 1353
                Are you on the throttle when it pushes? Springs on top of rear end and solid pull bar? Is pull bar centered on rear end bracket? Just some questions to help with your problem. Good luck.
                • Sportmod Rookie
                  • May 2012
                  • 60
                  Off throttle. Centered Solid pull bar. Springs above and centered on the axle. Thanks for all the help everyone. This is my first post and this forum is great.
                  • Sportmod Rookie
                    • May 2012
                    • 60
                    Weights.
                    LF 492 RF 519
                    LR 695 RR 595
                    Rear % 56.1
                    Left % 57.5
                    Cross % 52.6
                    Left side trailing arm. 20 degree
                    Right side trailing arm. 10 degree
                    Panhard bar 14 degree mounted about 2" below centerline of axle
                    1/4" toe
                    -2 caster +3 camer LF
                    +5 caster -3.5 camber rf
                    About 1/2" stagger front and 1 1/4" rear
                    2" lead
                    • Sportmod Rookie
                      • May 2012
                      • 60
                      The chassis is a DW8. Was thinking maybe of taking some angle out of the panhard bar and raising it an inch. Open for suggestions.....
                      • Hagen14t
                        • May 2011
                        • 167
                        -200 pounds of bite? Sounds like a problem to me.
                        • Sportmod Rookie
                          • May 2012
                          • 60
                          I must have wrote down the wrong weight for RR. Cuz car doesnt weight that much. Had to be about 595. Figuring that by total weight and what I had for rear %
                          • GUARDRAIL
                            • 35
                            I don't think that LS% is right. Looks more like 51.5% or so. Get about 30-90 lbs on the LF. That will help hold the car down.
                            • Sportmod Rookie
                              • May 2012
                              • 60
                              I was going to put a stiffer front right spring in. Would that actually make it worse then? If I want more weight to the front left where should I take/put turns in? Is 14 degree on the panhard bar way to much?
