need more drive coming off...help please
  • bluemod
    • 214
    car is good just need more drive coming off the corners. What can i do to get the drive im looking for thanks. This is a 4/4 bar.
  • oldtrackchamp4x
    • 270
    I just put more LR bite in my car. If that doesn't do it, then i raise LRU bar on frame. I don't do both as it makes car to tight. JMO
    • Egoracing
      • 4852
      Left bottom bar if you are on a typical 4 link with floated birdcages, Drop the bar on the chassis. This will tighten the car from the center off while on the gas without affecting the rest of the corner.
      • Dirtrunner35
        • May 2010
        • 632
        Where are you bars now ? Is this on a slick track ? Give more info about car.
        • bluemod
          • 214
          this is on a 1/2 mile high back track. does not get very slick. dont know degrees lrbb all way up, lrtb one hole from the top. rrbb almost level. rrtb one hole from the top.....rr tails 1/2 is that to much
          • bluemod
            • 214
            car does not hike up to much dont know if this is a problem
            • Dirtrunner35
              • May 2010
              • 632
              I think it's allot but every car and driver will be different, try a 1/4 or less. Tire pressure ?
              • JustAddDirt
                • 1893
                bite
                Front clip? Chevelle, Metric, Impala, Ford?
                springs?
                shocks?
                All this would be good info to give, so we can suggest a cure for your problem
                • bluemod
                  • 214
                  metric clip
                  lf800 rf750
                  lr200 rr175
                  shock are pro TA'S
                  lf 4/10 rf4/5
                  lr9/4 rr3/5
                  • washeduptoo
                    • 1353
                    That lrb bar seems like it might be high on frame, how much angle is that? If you have a b/c that has more holes on top of b/c you could lower it on b/c. I would try lowering lrb bar on frame first. Good luck.
                    • JustAddDirt
                      • 1893
                      help
                      Do you really have a 4/10 tie down shock on the LF?
                      Wow that is alot of tie down.
                      Wander if this being tied down too much will not let the car transfer weight to RR and make car seem loose off due to no weight transfer?
                      just a thought
                      or
                      did you mistake the front 2 shocks and the 4/10 is on the RF?
                      are you on a bumpstop on RF?
                      might have too much tie-down on the RF, and not letting it transfer weight back to LR .
                      • washeduptoo
                        • 1353
                        Didn't see that, that could be the problem.
                        • bluemod
                          • 214
                          so the shocks are backward in the front the 4/10 should be on the rf and the 4/5 on the left front
                          • washeduptoo
                            • 1353
                            If the 4 is compression and 10 or 5 is rebound, yes usually.
                            • JustAddDirt
                              • 1893
                              shocks
                              Yes.
                              If you are on that much tie down on the RF u should have a bumpstop on it. (atleast I think so)
                              I used to use that on a heavy track, then back off the rebound as the track got slicker.
                              but I have started using that big rebound with a bumpstop and it seems to work pretty well.
                              You can also go up on your RF spring a bit. that tie down will still let the weight transfer over on thr RF, and it holds it there, but it really needs somthing to push aginst (bumpstop) to give you max traction.
                              I have been running this setup @ eldora with great results.
