06 Flexi-Flier Gets Tight when track slicks off
  • romeropolo
    • Feb 2010
    • 24
    4/4 bar Afco edge shocks, 54% rear, 52% left, 30 lbs of bite, 850 RF, 750 LF, 200 LR spring in rear, 175 RR coil over in front, long biscuit bar w/ no 90/10 shock. Car is perfect when the track is heavy, as the slicks off the car just pushes like a dump truck. Changes we've made are wheel off sets and tire pressures. Reading in other post I am leaning toward moving the J-Bar up on the pinion(right now it is at its lowest hole) the rake is correct for the J-bar. This is the first year racing with the small metric chasis and still learning on how to make the changes to correct the tight issue. Does any one have experience with this issue and what are some of the other changes that can be made? Sorry for the long post and thanks in advance. 1/5 mile banked (Ventura Raceway)
  • AH55
    • 143
    Is the car on Nova lowers or Metric lowers? Also, have you tried running a 90/10?
    http://www.facebook.com/ArmondHolleyRacing
    • washeduptoo
      • 1353
      Are you making any changes between tacky and slick? Might try more stagger if you can. What angle are you bars at?
      • romeropolo
        • Feb 2010
        • 24
        The car has Metric lowers and the bar angles are LUB 22, LLB 7, RUB 17, RLB Level. We have changed the stagger with little effect. We are going to put the 90-10 shock on and raise the J-bar on the pinion up one hole, which will place it even with the pinion.
        • charcoal01
          • 545
          Where are you pushing, on entry, center, exit? Is it off throttle or on throttle?
          • romeropolo
            • Feb 2010
            • 24
            The car pushes off throttle on entry......driver really has to throttle the car to rotate it.
            • powerslide
              • 2696
              Are you spring behind on lr? if so what shock and where is it mounted on LR?
              • charcoal01
                • 545
                Have you tried swapping the front springs? That should free it up.
                • romeropolo
                  • Feb 2010
                  • 24
                  The LR has the spring behind and the shock in front, the RR is a coil over in front of the axle. Shocks are the AFCO Edge slick track package.
                  Both cages are floated and the LR brake is also floated.
                  • powerslide
                    • 2696
                    It sounds like the car is tight probably when its tacky but since the track is fast you can muscle around the tightness. How much trail in the rr? 850 in the RF of a metric w/ metric lowers is pretty soft. try 950 or 1000 and put the 850 in the lf.
                    i would also consider adding some angle to the RRL and RRU. raise RRL 5-7degrees that should effect entry only.
                    1/5th mile is tiny how do they get mods on that thing!!
                    • romeropolo
                      • Feb 2010
                      • 24
                      The track is very small check out this video. The Car with the issues is the number 14.
                      • drtrkr244
                        • 1024
                        Nice video......Looks like a good,little, racetrack.
                        From what I see, Ur shearing the rf contact patch(too stiff springs)
                        I had a customer last year who had a Pierce mod(metric front end).
                        Starting specs for that car were 650lf,600rf,200lr,200rr on a 3/8 track.
                        Car was still tight so I put in a 600Lf and it freed it up.
                        • JustAddDirt
                          • 1893
                          That is with Nova A-arms. this guy has metric's.
                          Car looked tight on entry, and through middle.
                          I would go up with the j-bar to pinion centerline and try it.
                          1 change at a time....
                          • romeropolo
                            • Feb 2010
                            • 24
                            Thanks every one for all the information, We are going with the J-Bar change. We will race next weekend and we'll see how she runs.....Thanks again!!!
                            • JustAddDirt
                              • 1893
                              tight
                              If it is still tight, raise RR lower 1 hole.
                              If it is still tight lower RR top bar 1 hole.
                              If still tight soften RF spring
