have a Pierce 700rf 750lf 200 rears on clamped rr spring on top . Running fast 1/4 mile j bar all the way up on frame. have 4-7 rf just a 75 lf lr has 8-2 rr is standard 94 the car is very loose in center off gas. running a j- bar. 4 bar left z link right side. my scaled left side % 53.2 . I am bigger guy so about 250 but with me still only 55.7% . Been told to much left side percent causes this. but numbers dont show that. I think the problem might be rear moves to left about 1-3/4 on hile up. is that to much or am I thinking wrong? Please help
Help .. Need help with sid bite.
Is this a spring behind or clamped on left rear ? My brother just called Bob and talked to him and we had the car set up wrong. Do you have his set up book? How are your rear bars set ?
Both bars are set at bottomes??????????? Not sure what you mean. Your front and lr shock is wrong. Try not to get off gas so much on entry.
both bottom bars are at 16" left side on four bar and right side z-link. Had straight bar on it but had that problem in center. So was trying the j-bar. the rear moved to the left almost 2" when car roles over. Bob told is not us that was to much. should only move around an inch or so. So your thinking the car is not staying up on the bars making it loose in center? Also what shocks would be best for standard set up? on lr and rf?
What holes are your left and right side bars in ?? I think my short bar is the third hole up on pinion, quick change. On slick do you take out rear steer ?
