I am new to leaf spring. I run multi leaf on both r and l. I can not run Fastboy set up. I run IMCA rules. What adjustments can I make for a lose car and what do I make for a tight car. I have read alot about the leafs spring cars and have seen that these cars are totally differant then the 3 bar ect cars. Any help would be awesome.
New to leaf springs. Any help would help out alot
Depends on the car and driver and what it's doing now. You allowed shackles ? Like ruef52 suggested tail weight
agree with the others.... load it up with fuel / weight in the slick.... move the shackles / front eye of the spring up and down to get it where you want.......(scales or trial and error)Originally posted by nebraskabowhunter View PostI am new to leaf spring. I run multi leaf on both r and l. I can not run Fastboy set up. I run IMCA rules. What adjustments can I make for a lose car and what do I make for a tight car. I have read alot about the leafs spring cars and have seen that these cars are totally differant then the 3 bar ect cars. Any help would be awesome.
Then everytime the car stops... put a jack under the car to hold it off the springs... never let it down on the springs unless the car is on the track or on a set of scales.... don't even tow it to the track sitting on the springs....block it up with something...... Or you will be buying leaf springs by the truck load......
Leaf springs can be real fast, they are real simple , they do the anti-squat deal better than anything... but you have to keep them fresh.....you can go broke buying multileaf springs if you don't keep the weight off of them......
Back before you could buy racing leaf springs.....I wasted a lot of my High School years pulling leaf springs out of a full body dirt race car and re-arching the leafs one at a time with a sledge hammer and an anvil......I think my hands still sting from the mis-hits when the spring was not level on the anvil......:-)" Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
I already do block the rear end when not in use. I do run shackles on both sides. The rear end of the car is loose in the middle. It will go into the corner and come out fine. It is in the middle were it seems to be loose.
Run a wheel spacer on the lft side. It will tighten in center. You could put some weight up high in the rear. A stiffer rt front spring or even a bit more cross. The springs could also be dying. Check the arch, if it is to far off they are dead. You will be able to tell real fast when they die. You may have to get them re arched.
Take a couple leaves out to the curb. yes, curb on the side of the road. Take your 5# shop hammer and use a blow that utilizes the corner of the hammer head, not a direct hit on the face of the hammer. Practice a little til you see how hard and get the feel for the hit and the bend.If you are a muffler shop you can use your tubing bender. Be very careful and don't put the center bolt hole within the shafts area. Same with using a hammer, don't try to bend them in or near the hole. Stay away from the surface area of the lowering block if possible.Remember arching in the center is just going to pull out when you tighten the u bolt plate down.*Not responsible for accidents of any kind. When you break one it may fly to heaven. Don't stand near the outer ends*Of course a professional is recommended. Have fun!BUCKLE UP NOW, YA HEAR?
a hydrolic press be safest way to re arch springs,...if your springs loseing rate to fast your running to light a rate springs to start with...the new stiff front segment springs are the hot ticket in leafs nowdays...white trash motorsports
These springs are new. They have 6 races on them. Would lowering or raising the rear of the spring in the shackle do anything. How much would tire presure change things.
Lowering the spring will add cross, and raising it will take cross out in the shackle. You say loose in the middle??? How are you driving the car in or are you making the car loose?
scale weight, tire pressures, shocks ? Does the car have a pull bar ?Last edited by Dirtrunner35; 05-24-2012, 10:41 PM.
Here are good simple basics..No where near as good as a 96 CT article I have though
http://www.circletrack.com/chassiste...ion/index.html.. I can fax you the other articles if you need them, and give you a few tricks, from Scooters bag!! 573 208 3528.. dont hesitate to call or txt.. Jason
