no forward coming off
  • Tnorton14
    • Jan 2012
    • 38
    Car is good in and through the center but I'm loosing everything off..have 126lbs of bite in the car always on a dry slick track..could this be a pullbar issue. Not sure how old the spring is in it because of the car being bought used...really good in and through the center but have no drive off for about thirty feet or so...looking for adjustments pullbar is 1 hole from bottom on frame and at the top of the mount on the q/c shock on the rear end is getting 3.5 in of travel. IV been told that is to much travel...any ideas...
  • rrcmotorsports
    • May 2012
    • 11
    126lbs of bite seems a bit high for a 4 link. Also you probably only have 3in. of travel on pull bar because on decel you'll push back into that shock. You can lower your RRU bar a hole and see what happens. Birdcages indexed?
    • Tnorton14
      • Jan 2012
      • 38
      Bird cages are indexed. Took the car from 86lbs of bite to 126 because of chassis builder recommendation....in the heat the car was wicked loose coming off with no forward so we moved the RRUB up a hole and it gave the car a push...IV been told softer rr spring but its got a 175 in it now I don't know how low I want to go...another thing IV been told.is lower my pullbar a hole on the frame...just looking for others opinions....
      • charcoal01
        • 545
        Are you tailing out loose or do you feel like the car is spinning it's tires and won't "go". If you're getting over 2 inches of travel on the pullbar it's too much. You're just wasting energy and slowing acceleration. I think you should find a stuffer spring until you're getting around an inch and a half of wrap.
        • powerslide
          • 2696
          how much angle in pullbar now?
          • Tnorton14
            • Jan 2012
            • 38
            12-13° I took the pullbar out today and looked at it closely I'm getting 1.5in of travel on the shaft that I can. Visibly see...the car feels like it wants to snap around on me and then I'm just spinning.for 30-40 feet down the straight till it hooks up
            • racin6mod
              • 2172
              sounds like it's not transfering the wt coming out what's the shock and spring rates?
              • Tnorton14
                • Jan 2012
                • 38
                175 LR 200 rr I'm not sure on the shock valving they are integra schrader valve shocks...I had the rr at 50psi and the lr at 230psi...its rolling over on the rr shock and.moving the indicator down.about 4 inches...
                • charcoal01
                  • 545
                  Where is your j bar? And your weight placement. You're probably loading the rr too much and it can't hold the traction anymore.
                  • mb20
                    • Oct 2008
                    • 117
                    I had the same problem. Turned out the right rear axle snout/tube was bent back slightly. Car was good in and mid turn was awesome on a tight track, but nothing coming off.
                    • Egoracing
                      • 4852
                      If the RR has more traction it is going to try to go around the front, Snap loose on the throttle. If the LR has more it is going to push thru the front, throttle push. Are you running a tru 4 link on birdcages or welded to the rear? Lowering the LR bottom bar will aid traction from the center off on the throttle, this was an adjustment that we used often on a slick track. It is also listed on the 4 link adjustment info on Integra Shocks tech pages.
                      • Tnorton14
                        • Jan 2012
                        • 38
                        A tru 4 link with bird cages. The LR lb is already as low as i can go...we put more angle in the pullbar and may even shift the pullbar off center to the left of the rear end as advised by my chassis builder....if that doesn't work he told me to put a 1/4in trail in the rr
                        • washeduptoo
                          • 1353
                          Angle in pull bar might help and moving pull bar left might also help.
                          You could lower the lrt bar on b/c if you have the holes to do that. Is your dampner shock an oil or high pressure gas, you could put a dummy shock there if its an oil dampner or a high pressure gas dampner shock. A high pressure lr shock with low rebound and high compression would help also. Both will cost though. Is your lf shock good? Had the problem more than once. Good luck.
                          • Tnorton14
                            • Jan 2012
                            • 38
                            Keeping everything on mind....just trying to get better. Will try tomarrow night and see how things go! I hope I'm not fighting this all weekend as I plan to run a few nights this weekend d
                            • powerslide
                              • 2696
                              More angle in pullbar should help 12 is pretty low. More trail will free the car more. I think he meant take trail out
