tire temps
  • amod53
    • Dec 2011
    • 103
    tire temps
    If you come in after your feature and your left rear tire is cold to the touch and your right rear is extremely hot to the touch then what tire is working and what adjustment would you do to the car? Dry slick conditions!!!
  • drtrkr244
    • 1024
    How did the car handle?
    • Dirtrunner35
      • May 2010
      • 632
      Friday night my LR tire was more then luke warm and the RR was really hot, my car was a little too loose. For saturday I made some changes and my LR wasn't warm and the RR was luke warm, much better.
      • Windy
        • 42
        tire temp
        hottest tire doing the most work..try to get close to even temps..~v~..
        • racin6mod
          • 2172
          with a heat gun mine showed about 10 degree's difference after a feature with a tires. our lm showed pretty much the same diff. but higher temps.
          how high was the left front.
          • Graff Spee
            • 881
            What changes did you make?
            • pockrus48
              • Mar 2009
              • 42
              I have the same problem, after the feature the RR (A) was 153 degrees and the LR (D) was 110 degrees. Going to try running more LR bite and see what happens.
