need gear help asap
  • bobracing32
    • Sep 2011
    • 10
    need gear help asap
    im running a 543 and need more speed off the corner do i go to a 67 or 83
  • circle dirt
    • 742
    Do have room at the end of the straight for more rpms? If so , jump up a gear. More gear will get off the corner better but hurt top end depending on the track size
    • DaveBauerSS6
      • Jun 2010
      • 566
      Agreed, go as high as you can. Consider the components in the motor, a chip if you are limited, and if the motor is pulling at the end of the straight.
      Are you getting on the gas earlier than anyone else? If not , you need to work on setup.
      Gator Engineering
