Axles
  • Dirtrunner35
    • May 2010
    • 632
    Axles
    I have a ford 9 inch with coleman snouts on it, it has wide 5 axles in it. Couldn't I use GN axles in this. The only difference I can see is the GN axles are bigger at the end for a seal. Thanks.
  • dirttrackrocker
    • Nov 2010
    • 664
    I don't see why not.
    • hammond
      • 414
      You will need to run the wide five axle because where the step in the GN for the seal is will hit the snout .
      www.hammondmotorsports.com
      http://www.facebook.com/#!/pages/Ham...26044754164488
      • Bcollins82
        • Jul 2009
        • 322
        Hammond is right, the axles will slide in and you think they're fine but as we found out, the friction of them rubbing together took half a lap for the axle to weld itself to the snout! Then you have to cut the snout off and have the rearend fixed and junk your axle.
        • Dirtrunner35
          • May 2010
          • 632
          Thanks guys, you are correct. My brother checked the clearance and it's really close. I'll use the wide 5 axles.
          • z40chief
            • 90
            Moser Engineering takes their lifetime guaranteed axles and turn the ends to fit the coleman snouts. I don't see why your local machine shop couldn't do that for you. From the 2 sets I have bought they appear to machine grind them to fit.
