Lifting the lf tire
  • bobracing32
    • Sep 2011
    • 10
    Lifting the lf tire
    I know it looks cool to hold it up. Most of you will say its pointless or not fast. This is the only setup ive never tried. Theres a practice day at a local track and i just want to try it out. I will need any and all help with set ups and numbers. Currently running a sportmod 3 link 07 harris. I cannot get the left front tire to lift at all. lf 500 lr 450 lr 225 rr 175 53% rear 50.2 cross. With 100lb split between lr and rr. What should i do with my numbers or add weight somewhere?
  • racinjj
    • 98
    Its almost completely dictated by your left rear trailing arm angle, more angle = more lift. 25degrees should get you flying, then you will realize how much better it is with the LF on the ground.
    www.UltimateRaceCars.com
    • powerslide
      • 2696
      doesnt matter how much angle it has if the rearend cant drop far enough. you will need around 5in's of drop in the LR to get the LF up.
      • JHobbs26
        • Aug 2007
        • 146
        This is close to 6" of travel on the LR. LF will lift up about 3-6" but nothing too drastic. This pic was taken last weekend @ Humboldt, KS. I was running a 15" shorty panhard bar also. So, as you can see, it all depends on a lot of things.
        • JHobbs26
          • Aug 2007
          • 146
          This was also the last race for this car. Its getting introduced to the sawzall this weekend
          • powerslide
            • 2696
            whats wrong w/ it?
            • racin6mod
              • 2172
              I'm betting forward bite is less than driver wants.
              • JHobbs26
                • Aug 2007
                • 146
                the car needs a front clip.
